Car is shaking at fast speed
Old Apr 9, 2005 | 12:23 PM
bleedhondos's Avatar
Default Car is shaking at fast speed
I just recently got my 17 rims and tires install, plus alignment done and my steering wheel is shaking at 80 miles and up. I'm thinking i should go back and have them recheck my alignment. Anyone have a reason why its doing that?
Old Apr 9, 2005 | 01:47 PM
civic96RB's Avatar
Default RE: Car is shaking at fast speed
mine does that 2...havent figured out why but when you find an answer both of our problems will be solved
Old Apr 9, 2005 | 03:25 PM
Pete's Avatar
mine does it too........i think its cuz the rims? idk anyone?
Old Apr 9, 2005 | 04:21 PM
sacicons's Avatar
get the wheels rebalanced. if they were just installed, it should be covered. thats probably the problem.
Old Apr 9, 2005 | 04:58 PM
Pete's Avatar
negitive.........my **** shakes too.........wheels were brand new and came balanced.......would alignment help?
Old Apr 9, 2005 | 05:34 PM
same thing, wheel came new and it was balance and already got my alignment done. anyone know why?
Old Apr 9, 2005 | 06:24 PM
sacicons's Avatar
it could be a bunch of things. does it only do it while braking? warped rotors. does it do it all the time? ball joint, tie-rod end, possibly an alignment issue, bad tire, pressures wrong, axle, wheel bearings, maybe even a wierd road surface? ive thought something was wrong with my car before, then it went away when i turned onto a different road.[&:] sorry this doesnt narrow it down too much.
Old Apr 9, 2005 | 08:24 PM
ineedhp's Avatar
that same thing was happening to me too! my wheels were balanced twice. turned out that my tie rods were going out and my rotors weren't pretty either. i would check those before you do anything else. if it is soemthing else, please post!
Old Apr 9, 2005 | 10:12 PM
Pete's Avatar
lol just installed new crossed drilled rotors and pads so that aint it.........but check it.......i had the stock hubbies on before the rims..........so i went from 14inches to 17 inches.......can that be it?..............i got me wheels at wheelmax.com .......maybe theyre machine balances wheels up to 75 MPH......??
Old Apr 9, 2005 | 10:51 PM
ineedhp's Avatar
i've heard that they don't do a very good job at balancing. my buddy got some wheels from there and they weren't balanced at all. but i would check out the suspension before you got them done again.
