Car Swaying When turning
When i turn sharp or pull coners a little faster, the car leans to one side or the other. I know it's not bad shocks, I replaced them less than a few months ago. Does a sway bar solve this problem. also, I want to stiffen my suspension, but i don't want to change my shocks, they're brand new, and I don't want it lowered or anything. I want the ride height to stay the same, just stiffer suspension. any help or ideas?! Thanks to all!!!!
RE: Car Swaying When turning
sways will make the biggest difference, also the lower you get it to the ground, the less roll you will have.
I have a very simple setup and I get almost no roll at all. Its like point and go
(lowering springs, sways, and a strut bar)
ist his what i'm looking for?!?! I'm pretty sure the brand is trustworthy. Is the price expensive, reasonable, what?!?! I'm pretty sure this is what I need. I can't seem to find too many sway bars for my car!! Help please! if the proce is a little high i'm willing to pay for the quality, I DONOT WANT GARBAGE! This is probably going to be one of my biggest mods yet besides putting in my own system!!! I hat 5 1/2 is the rear and i stripped it and cut out holes for 6x9's and put them in I took them out of a 93 lincoln continental. That's what i used to drive so i know this thing BuMPS!!! Thanks, Josh
http://www.performancecenter.com/pro...oductID=366405
Sway bars are all basically the same and do the same thing. The more expensive sway bars usually are made of a lighter material to save weight. And if you are woried about saving a couple of ounces then go buy an expensive one. But you can find ones for as cheap as $20 or $30 like the ones on www.makotoautotrends.com they are still fairly rigid and will get the job done. As far as springs go, H&R springs have a type of spring set that are called OEM springs that stiffen you ride up and still mantain your stock height. And you can still keep your shocks you have in your car now.
