Civic 2006 Brake Pedal all the way down to stop
Hello,
I was wondering what are the possible causes that when I press the brake pedal I need to really push it all they way down to stop the car. I took it to the shop but I do still fill the same.
Thoughts?
Thanks for your help,
G
Thoughts?
G
My money would be air in the brake lines. Try having the brakes bled at a reputable shop (or do it yourself) and that should fix the problem.
*edit: just realized the problem was present before the car was taken to a shop... could definitely be a master cylinder issue as well. I'd start by bleeding the brakes, though, as it's borderline free to do yourself (free if you already have brake fluid laying around, a few bucks for brake fluid if you don't).
If they did flush/bleed the brake system, that leaves the master cylinder. When you are at a complete stop for a minute, like at a stop light, when you hold the brake pedal, does the pedal slowly go down to the floor?
jberenyi
Mar 6, 2012 12:47 PM
Juans_MX3
Apr 7, 2010 03:38 PM
Ed Fisher
Aug 20, 2009 11:47 AM
Güero
Jun 24, 2008 08:58 PM
