Civic Si parts
Old Apr 9, 2007 | 12:35 AM
Partizan's Avatar
Default Civic Si parts
So I might be buying some civic si 99-00 parts tomorrow- front and rear sway bar and front strut bar. Is the front sway bar any better than the one i already have on my 96 civic ex coupe? For the rear sway bar, would this bolt this right in to my car? And im guessing the front strut bar would fit, but i gotta drill the holes?
Old Apr 9, 2007 | 12:39 AM
skateman190's Avatar
Default RE: Civic Si parts
for a front strut bar u dont have to drill anything, just take the nuts off the top of your struts(the outer ones, lol.) and slap that bad boy on and tighten it down. the rest should bolt right up as well.
Old Apr 9, 2007 | 09:19 AM
cderalow's Avatar
you may or may not have the holes in the rear for the rear sway bar... might require the rear lca's from the si to bolt up properly
make sure to get all of the mouting hardware and bushings for the sway bars
Old Apr 9, 2007 | 04:36 PM
mybrokenblinker's Avatar
i'm almost postiteve 96 lca's do NOT have the bolt up for the rear sway. Or at least mine don't. New lca's aren't very expensive though, or you could drill a hole yourself.
Old Apr 9, 2007 | 05:24 PM
Nail I3unny's Avatar
skateman said 'nuts'. hahahahahaha.
when you're replacing them make sure not to take off the center nut. thats the one that holds your suspension together. take off the outer two on each side, put the bar and some washers on, tighten the nuts back down, and you're done. its probably the easiest mod for the performance increase.
Old Apr 9, 2007 | 06:15 PM
^^is right, mine was a bolt up for teh ef, i dont know for sure on the newer styles, my bad
Old Apr 9, 2007 | 06:22 PM
wait...the upper front tie bar from an Si wont work on any other civic unless you drill holes for it.
MarcB
Jan 26, 2007 06:57 PM
gablagloire
Aug 19, 2006 04:30 PM
TRILOGY
Jul 16, 2006 04:52 PM
mabus013
Oct 4, 2005 02:46 PM
littledog
EG Swaps
Sep 29, 2005 07:01 PM
