DoT Approved Big Brake Kit
Hey.. was just looking up the Wilwood big brake kits.. as suggested through an old post on here but found out they are not DOT approved.. which im sure means non inspectable.. I did find a Force 10 brand brake kit for 650 bucks.. with 12" rotors.. has anyone heard of this brand .. or have any other input on whether DoT approved is in fact required for an inspected vehicle??
http://store.summitracing.com/defaul...earchType=Make
http://www.jegs.com/webapp/wcs/store...tegoryId=21583
check out www.fastbrakes.com they got some good stuff, just remember that with a 12in rotor you will probably need at least some 16s but that owuld be pushing it will need 17s for a good fit
Going to be putting 17's on when i install brakes.. need larger brake kit for the B16A or B18C swap ill be doing.. will be tuned for 200whp by the time im done next month.. still working on which route to go on the engine.. that and availability of engine..
I already warped my rotors though.. i am frequently braking from over 100
also just called and spoke to a mechanic about what is inspectable.. he said that if he noticed aftermarket brake kit on a vehicle that he would require the DoT approval on the box or he would fail it.. also he said without upgrading my master cylinder.. it would be pointless to get 4 piston brakes over the cheaper 2 piston stainless steel brakes as there would not be enough brake fluid flow.. can anyone confirm this ?
ORIGINAL: mentaldis0rder
so just the brembo slotted rotors and new brake pads should be enough then for hardcore street app?.. just wanna make sure im stopping when going over 100.. right now even with stock engine i cant stop without mashing the brakes hard to try to lock em up.. i have been using the ebrake while braking lately to cut down on the front end shaking from stock warped rotors.. i have also been trying to find out about just pulling a GSR or SI brakes.. dunno if they are just a straight swap though.. no one i know has done this around here..
I dont use car for track but i drive a little in excess of speed limits ..
i have a gsr in my sol. not 200whp but its still quick and my front end shook when i braked over 75. i got power slot rotors and aem brake pads i think it was under 200 all together. i got them from a&a and i can brake quick even at 100 real smooth.
Thank you very much.. thats exactly what i was looking for.. someone who has done it. That wil probly be route i go then,, and maybe upgrade rear discs later.. anyone know link for decent rear disc conversion that will match stock rotors by chance?
