EK subframe vs. EG subframe
Roto didnt think they were different
lol. left pic is a random EK i found and right pic is my car.
you can see that the EK d-bracket mounting holes are on the outside as oppose to the EG which has them towards the inside. this is the reason why the EK subframes are weaker than the EG's and are more known for having a subframe torn out when not using proper bracing when adding a thick rear sway bar. if you do use a thick sway bar, no matter on EK or EG, it is important to use the proper bracing such as the Beaks or ASR kits.
upnorthguy
Oct 23, 2012 05:39 AM
fecker
Canada, Over Seas & Elsewhere
Apr 18, 2007 11:19 AM
Washingtonian95si
Feb 19, 2007 10:36 AM
