A few Questions????
Old Oct 20, 2007 | 02:31 PM
trichard310's Avatar
Default A few Questions????
I have a couple of questions. Will 17's with 45 series tires fit under my car without rubbing? Has anyone heard of "bump steer"?(car shakes at high speeds, pulls one way or the other after bumps or pot holes).
Old Oct 20, 2007 | 02:46 PM
Default RE: A few Questions????
Is your car lowered? 45's will probably rub if you are, but I don't think you'll have problems if you're at stock height. If you are lowered, I'd say get 205/40's and you shouldn't have any problems, assuming you have the right offset wheels. And what do you need to know about bump steer?
Old Oct 20, 2007 | 03:31 PM
I had to put a camber kit on the rear and it looks a little lower in thebackbut, the guyI got the car from said it was not lowered. What offset should I go with? I want to know how to fix the bump steer, it drives me crazy?
oldguy
Mar 17, 2007 01:03 PM
ThisWay84
Jul 2, 2005 09:21 AM
mitch_cox_kc
May 27, 2005 05:06 PM
Orin
Apr 1, 2005 11:36 AM
foozball
May 25, 2004 11:56 PM
