having some brake issues, diagnosis?
Here's the conversation I just had with my wife
:Emily gets home emily "come help! there's something wrong with my car" (98 dx hatch) me "what's wrong?" emily "its going bu-bu-bu-bu-bu-bu-bu when I press the brakes" me "whats going bu-bu-bu-bu-bu-bu-bu?" emily "the car.. when I brake" :I test drive the car. It does not go bu-bu-bu-bu-bu-bu-bu me "did you feel or hear the bu-bu-bu-bu-bu-bu-bu?" emily "I felt it through the brake pedal" So guys and gals, any idea what would make the brake pedal go "bu-bu-bu-bu-bu-bu-bu"? It apparently doesn't effect the braking performance, does it with light or heavy braking, on straitaways or turns, and doesn't do it for me :D btw. that conversation is actually funny only if you can hear her saying "bu-bu-bu-bu-bu-bu-bu" |
RE: having some brake issues, diagnosis?
pppth. haha.
honestly...could be the pads are old or rotors are slightly warped...slightly to the point where it only affects braking when they heat up. brake fluid? idk. |
could be that a Caliper is sticking, that was what happend to be, ended up having to replace the caliper, rotor(cause it got so warm it warped and glazed over), and the pads
hopefully something simple like that. The only thing that weirds me out is that she says she only felt it through the pedal.
it also could be tire pressure too low...check that first
just did the oil, filter, fluids, tire pressure thing a couple days ago
I just rotated the tires, but I'd think if that was a problem it would do it all the time. I guess it'll just have to stay a mystery. I told her to give extra room for braking in case something goes out again and if all else fails, to pull SOFTLY on the ebrake or shift into lower gears. (this is more my attempt to get her driving sanely than any real worry of a big problem) :D |
Take it to the brake shop they should know what wrong with it.
ORIGINAL: importcivicus Take it to the brake shop they should know what wrong with it. |
No ABS. I believe we should let darwinism take its natural course ;)
I agree with agent on the brake shops, but there is one mechanic I trust around here in Grand Rapids. If it happens again and I can't find anything wrong, I'll take the car in to his shop. |
My guess is the rotor needs to be machined.
