having some brake issues, diagnosis?
Old Jul 24, 2006 | 06:15 PM
Stimpy's Avatar
Default having some brake issues, diagnosis?
Here's the conversation I just had with my wife
:Emily gets home
emily "come help! there's something wrong with my car" (98 dx hatch)
me "what's wrong?"
emily "its going bu-bu-bu-bu-bu-bu-bu when I press the brakes"
me "whats going bu-bu-bu-bu-bu-bu-bu?"
emily "the car.. when I brake"
:I test drive the car. It does not go bu-bu-bu-bu-bu-bu-bu
me "did you feel or hear the bu-bu-bu-bu-bu-bu-bu?"
emily "I felt it through the brake pedal"
So guys and gals, any idea what would make the brake pedal go "bu-bu-bu-bu-bu-bu-bu"? It apparently doesn't effect the braking performance, does it with light or heavy braking, on straitaways or turns, and doesn't do it for me
btw. that conversation is actually funny only if you can hear her saying "bu-bu-bu-bu-bu-bu-bu"
Old Jul 24, 2006 | 06:53 PM
Nail I3unny's Avatar
Default RE: having some brake issues, diagnosis?
pppth. haha.
honestly...could be the pads are old or rotors are slightly warped...slightly to the point where it only affects braking when they heat up. brake fluid? idk.
Old Jul 24, 2006 | 07:21 PM
Fiirkan's Avatar
could be that a Caliper is sticking, that was what happend to be, ended up having to replace the caliper, rotor(cause it got so warm it warped and glazed over), and the pads
Old Jul 25, 2006 | 04:55 AM
Stimpy's Avatar
hopefully something simple like that. The only thing that weirds me out is that she says she only felt it through the pedal.
Old Jul 25, 2006 | 08:20 AM
StifflersMom's Avatar
Cat Fuсker
it also could be tire pressure too low...check that first
Old Jul 25, 2006 | 05:16 PM
Stimpy's Avatar
just did the oil, filter, fluids, tire pressure thing a couple days ago
I just rotated the tires, but I'd think if that was a problem it would do it all the time.
I guess it'll just have to stay a mystery. I told her to give extra room for braking in case something goes out again and if all else fails, to pull SOFTLY on the ebrake or shift into lower gears.
(this is more my attempt to get her driving sanely than any real worry of a big problem)
Old Jul 25, 2006 | 06:56 PM
importcivicus's Avatar
Take it to the brake shop they should know what wrong with it.
Old Jul 26, 2006 | 01:52 AM
AgentofDarkness's Avatar
ORIGINAL: importcivicus
Bah! They jus wanna sell you stuff. Im assuming that the bu-bu-bu is a brake pedal pulsation. Is your car ABS equipped? When the does the pulsation occur? If the rotors are warped then the pedal will pulsate when slowing down from higher speeds (shouldn't happen at like 10). Since your labor is free, i would take the front brakes apart (caliper off) and look for anything out of place. Do the same with the rear, just don't screw with anything in the back cause drums are a major PITA
Old Jul 26, 2006 | 04:46 PM
Stimpy's Avatar
No ABS. I believe we should let darwinism take its natural course
I agree with agent on the brake shops, but there is one mechanic I trust around here in Grand Rapids. If it happens again and I can't find anything wrong, I'll take the car in to his shop.
Old Jul 26, 2006 | 06:44 PM
pWnEdU's Avatar
My guess is the rotor needs to be machined.
kclay1989
Feb 4, 2015 05:49 AM
Davo53209
Jan 13, 2012 07:47 PM
Sean James
Nov 26, 2010 09:30 PM
red2000Si
Aug 30, 2006 07:36 AM
WrongfulWright
Jun 2, 2006 10:09 AM
