help?
i have noticed that in the back my tires wont "tuck" very well. they will hit the fender instead. tonight they TUCKED alright when i hit a pothole going 85. its riding like a tank right now because the tire is like jammed up inside there and hitting the fender. what should i do? i guess just jack it up and hope it goes back normal? and what about fender rolling? anybody have this done? should i get it done?
RE: help?
What size tires are you running? (ie. 205/45R17)
Do you have coilovers, non coilovers? Do you have a camber kit? |
RE: help?
ouch... that's weird that only the back is messed up, I would think the front would take most of the impact.
I'd jack it up, pull the wheel off, and just take a look at everything... I hope nothing's bent. |
RE: help?
205/40/17....yes i have a camber kit. i really hope nothing is messed up too. im about to check it out. ---well, just went in the garage and jacked it up without taking the tire off and about 10 seconds of it jacked up there was a lpud popping noise....like the spring coming un compressed or something....i dunno but i looked at everything and didnt see anything out of the ordinary. the only thing was my bumpstops are jammed in the dust boot but i dont think that matters. i lowered the car and now it is back to the height i had it set at....1 finger between the tire and fender....so what could it have been? im assuming everything is ok.
RE: help?
Well, it could have been that when you lowered the car before that one of the rear springs wasn't sitting properly. I have to worry about the with my coilovers. It's seems that if I don't check the spring will flop on an angle with jacked up.
RE: help?
it was fine before until i hit that pothole though. everything is ok now i guess i drove about 50 miles and no problems....i guess its good again
RE: help?
ORIGINAL: danomatic93 Well, it could have been that when you lowered the car before that one of the rear springs wasn't sitting properly. I have to worry about the with my coilovers. It's seems that if I don't check the spring will flop on an angle with jacked up. |
RE: help?
sounds like prolly the only thing that may be messed up is alignment, u can prolly get it checked for free at ur local dealership, just ask to go over the slip test. if u want to prevent that from happening again, fender rolling would prolly be a good idea. its usually cheaper to find someone with a real fender roller(not a baseball bat...) and have them do it. u'll prolly crack a lilpaint on the fender but nothing some touch up paint cant handle.
