humming sound from the front
Old Feb 9, 2008 | 12:08 AM
hovo61788's Avatar
Default humming sound from the front
ok i was driving to work today and i heard a humming sound from my car only when i turn right. i hear the humming sound even when i turn to the right slightly. my car needs axles could that be why? a coworker said it could be some sort of bearing or bushing? i dont know it just pisses me off, i fix one thing and another thing starts to crap out on me. my car isnt lowered at all. if you need more info let me know. please help me out!
thanks guys
Old Feb 9, 2008 | 05:56 AM
Default RE: humming sound from the front
Is the power steering fluid topped off?
Axles definitely will become noisy when they are bad. When you replace them, also inspect the front suspension components for excessive free play.
Old Feb 9, 2008 | 08:38 AM
KarTuneMan's Avatar
What kind of miles on the odometer? Bearings don't last forever. Did you determine the need for axles yourself, or was this done by a qualified technician? (not to say you are not qualified, I don't know you) An axle, or CV joint typically won't make the type of noise you are describing. That nasty "hum" is usually a bearing.
Stock suspention, stock tires and wheels? You'll find out real quick what the issue is.....after you do your axles, and CV joints.
Old Feb 9, 2008 | 09:18 AM
riceburner700's Avatar
Wheel bearings make a humming sound while you drive and a clunking sound when you hit a bump when there going out. Might look into a wheel bearing
Old Feb 9, 2008 | 09:25 AM
Fiirkan's Avatar
ORIGINAL: riceburner700
+1
Old Feb 9, 2008 | 09:49 AM
hovo61788's Avatar
power steering fluid is topped off, i driving around with 205/60/15s but ive had them for a few months.my mechanic told me it needed new axles, the boots are all messed up.how much do bearings cost and are they easy to change?
javadeside
Nov 7, 2021 09:39 AM
ianmckee
May 30, 2008 05:42 AM
n8te81
Mar 5, 2008 10:20 PM
rsboy
Aug 6, 2007 04:45 AM
scottyb2fast
Apr 13, 2007 05:10 PM
