I need a good tire.
Old Jul 28, 2007 | 09:43 AM
Lost's Avatar
Default I need a good tire.
Anyone have any ideas for a sport tire that is great on wet roads but also can perform?
Old Jul 28, 2007 | 10:25 AM
SilverSedan's Avatar
Default RE: I need a good tire.
Personally I'm running on BF Goodrich Traction TA's. All season tire, good pricce, so far I'm pretty happy with them. I don't push then SUPER hard, but they've far better then any other tire I've run on. Great in the wet, I've tried to MAKE them hydroplane....and they just didn't. They'll chew through water and find traction. Winter (snow and ice) traction is pretty good as well. I did research on
www.tirerack.com
www.epinions.com
the only complaint I have with them so far is they are somewhat noisy...but oh well. Paid just over $500 (CDN) for all 4, mounted ballanced and installed.
Old Jul 28, 2007 | 10:45 AM
Lost's Avatar
thats for the info sir.
Old Jul 28, 2007 | 10:52 AM
burgernuds's Avatar
i use the toyo proxes 4 and I think they are great at 100 bucks each
Old Jul 28, 2007 | 01:01 PM
okynot43's Avatar
I just got some new tires, Kumho Ecsta AST's...decent tire for the price, I paid 50 each for them at tirerack...they had pretty good ratings for the price.
http://www.tirerack.com/tires/tires....odel=Ecsta+AST
Old Jul 28, 2007 | 08:43 PM
conceptualpolymer's Avatar
...then check a recent edition of Car & Driver. Although they used "only" a 325 BMW as a test mule, you are very likely to experience similar results with your Honda. To minimize variables such as driving techniques, track surface temps, etc, C&D enlisted the help of the Tire Rack and their test mule vehicle. Although the track used was small, it's lined with sprinklers that can soak the asphalt. "It took three days to perform all the tests. We accerated to 50 mph and then braked to a standstill. There was a benefit to that lower speed: It ensured that we were measuring the braking performance of the tires and not just brake fade."
"In addition to factoring the wet and dry scores, we gave points based on a tires's price and tread-wear grade, which is a rough estimate of how long a tire will have usable tread." "Our test focused on measuring performance, so we decided that results in the dry-lateral grip, for example - would carry the most weight."
So, without further adeau, here're the results:
(Best to worst):
NUMBER 1: Goodyear GSD3: "As an all-around performance tire, you can't beat this Goodyear. It was the best performer in all three wet-track tests and was very competent in the dry. It generated .94g on the dry skidpad, only .01g off the first place (dry) BFGoodrich and tied with the Yokohama and Hankook.
The Goodyear gripped so well, that you might not have been certain that the road was wet. It held onto the wet track with .82g of stick, an impressive figure considering the worst tire in that test made only .67g.
...And like the Continental, the Goodyear had a high 280 trad-wear grade. At $145, ieach, it's $34 cheaper than the most expensive (guess which tires have THAT distinction!).
2nd place: Continental ContiSportContact 2: "It simply didn't feel as sporty as the others.....on dry surfaces, the Conti never rose above third from last among 11 tires. It felt soft and imprecise. But in the wet, the spread from best to worse was 15 percent, which made for a larger point spread (giving the Contis a boost). Plus the Continental had a 280tread-wear grade that was the highest (tied) for this test.
3rd place: Yokohama Advan Neova AD07: Excellent dry performance, but a bit on the slippery end in the wet stuff - expensive at $175 apiece.
4th place: Michelin Pilot Sport PS2: "At $179, the PS2 is the most expensive tire in the test." Competent, but expensive sums up this tire.
5th place: Hankook Ventus R-S2 Z212: At $99 each, these are the least expensive tires - very good on dry pavement, but "greasy and slow to recover" on the wet stuff.
6th place: Dunlop SP Sport Max: "In the dry, the tire seemed to lose its confidence..."
7th place: Pirelli P Zero Rosso Asimmetrico:"In the dry-lateral-grip test, the Pirelli tied for second to last, and it finished seventh in the dry-braking test.
8th place: Toyo Proxes T1R: "...the Proxes never placed higher than eighth in any test"...nuff said!
9th place: Bridgestone Potenza RE050A: "it felt dull and disconnected and was somewhat soft and imprecise when driven hard."
10th place: BFGoodrich g-Force T/A KD: Outstanding performance on dry surfaces, but very scary on wet surfaces - don't get caught in a rainstorm wearing these shoes...
11th place: Kumho Ecsta MX: "They didn't offer much grip and the time of 30.28 seconds in the dry autocross was .62 second slower than the fastest tire. That may not seem like much, but our course was only 0.3 mille long, and on a longer track, that gap would be commensurately greater." "And although the MX - at $136 per - was the third-least-expensive tire in our test, the high score in the price category wasn't enough to regain ground lost in the performance tests."
I HAVE heard good things about Avon tires, as well. They are VERY inexpensive.
Old Jul 28, 2007 | 08:45 PM
ej6buddy's Avatar
michelin pilots are some of the best quality tires you can buy. i personally have BFGoodrich G sports, and they're "VERY NICE" <borat>
Old Jul 28, 2007 | 08:50 PM
mybrokenblinker's Avatar
I'm surprised no one has mentioned falken azenis...they are the staple of autocrossers everywhere, but theyre not that great in the rain.
Old Jul 28, 2007 | 08:53 PM
ej6buddy's Avatar
ORIGINAL: mybrokenblinker
that's just it, they're good for autocrossing, they're ok for street depending on what ride you're going for.
Old Jul 28, 2007 | 11:42 PM
TheMoogly's Avatar
Toyo Proxes 4 or Toyo T1Rs... they are sexy
