Install lowering springs yourself
Old Nov 4, 2006 | 03:48 PM
jomacba's Avatar
Default Install lowering springs yourself
Im curious. Ive taken a look at my suspension, and i know i can install the springs myself. The question is, am I an idiot for thinking so? if not are there any special tools that I would need, besides the obvious (socket set and a couple wrenches, and maby and allen key or two. I saw a pic with a bracket on a spring, looked to be what i would call a spring compression unit or whatnot. either way, would i need one of those??
Old Nov 4, 2006 | 03:52 PM
mill$civic's Avatar
Default RE: Install lowering springs yourself
http://www.honda-tech.com/zerothread/1106020
here you go
Old Nov 4, 2006 | 06:45 PM
amg6975's Avatar
You're going to want a spring compressor.
Or you can have Marnie explain how to do it the fun way.
Old Nov 4, 2006 | 08:40 PM
Rickimaru's Avatar
you might need a tie rod seperator too but that will run you like $10
Old Nov 4, 2006 | 11:00 PM
Nail I3unny's Avatar
ORIGINAL: amg6975
is that the one where you put it on the jack slightly but only so the car doesnt fall apart...then take apart all three bolts at the top so you use the cars weight as a spring compressor?
Old Nov 4, 2006 | 11:14 PM
Belmont's Avatar
Or you could have a freind/neighbor/anyone over 150 pounds to put some weight on the spring while you unscrew the bolt.
Old Nov 5, 2006 | 12:45 AM
civicexracer's Avatar
https://www.hondacivicforum.com/m_225963/tm.htm
highly recommend help from some friends that might have prior hands on experience. its not difficult but u might run into a few questions.
Old Nov 5, 2006 | 12:22 PM
jomacba's Avatar
exellant, i appreciate all the help.
Old Nov 5, 2006 | 10:16 PM
cbaber's Avatar
I just installed lowering springs on my civic this weekend. Its pretty easy to do, even for a 16 year old who has just started figuring out a civic. Beware of the bolt holding the strut on the control arm. It likes to break if your not careful. Play it safe and take the whole piece out.
Old Nov 5, 2006 | 10:25 PM
drbyers's Avatar
when you say "weekend", do you mean over the course of a few hours or a few days? lol.
