lowering ?
i ask ppl from work and they dont help at all but anyways i got a 98 4dr civic stock suspennsion and i have 17*7 rims on there now i was wondering if i could lower an inch without any rubbing problems well since i have a 4 dr i carry some friends around and when i turn u hear it rub :( is there a way to go around this problem like a special spring or whatever?? thanks
RE: lowering ?
How can you lower it more if it rubs already?
RE: lowering ?
If you are rubbing on 17s already, and you are not lowered, then something's either gotta be wrong with your current suspension, or the wheel/tire combo you're running isn't correct.
What size tire and wheel? What's the offset? |
RE: lowering ?
yea rubbing with 17s doesnt sound rite
RE: lowering ?
get your fenders rolled
RE: lowering ?
yeah getting the fenders rolled would help...but hes not lowered at the moment and he should not be rubbing with his stock suspension..somthing gotta be wrong..
RE: lowering ?
Ya man I don't think that you are rubbing.. That might be something else.. one of my buddys has a eg h/b lowerreally low and with 17 he only rubs when the wheel is cranked over almost the whole way
RE: lowering ?
are your mud covers inside the wheel wells attached? If they're hanging low that could be the rubbing...
RE: lowering ?
If im going for a TEIN flex or basic damper on a 00 ex, will it lower? and rub?
RE: lowering ?
they are adjustable so no you wont^^^ I lowered my car 3 inches on 15s and the only time i rubbed is when i turn as hard as it will go. on the plastic bolts holding the fender well skirt on
