Need S Tech help. probably fast
Old Apr 14, 2007 | 04:06 PM
Nochek's Avatar
Default Need S Tech help. probably fast
I installed my Stechs on my Illuminas, in a 2000 EX.
I put the shorter springs in front and the taller in back, but theres a 5 inch gap in the back and it covers an inch of the front tires.
Did I put my springs on wrong?
Old Apr 14, 2007 | 04:55 PM
jhsplaya08's Avatar
Default RE: Need S Tech help. probably fast
probably so then. is there any #'s on the springs? if so, the higher # goes up front. my coilovers, the springs were taller up front. if you said there is a 5" gap, something is wrong.
Old Apr 14, 2007 | 06:10 PM
ScoobyAddict14's Avatar
formerly aryiman98civic
sounds like you did put them on wrong. check the numbers again and tell us what the spring rating is for the springs. the higher numbers go in the front like jhsplaya said.
Old Apr 14, 2007 | 07:48 PM
mill$civic's Avatar
Ya you deffintly did.
Old Apr 14, 2007 | 08:01 PM
drbyers's Avatar
pwnt by some coil springs... lol.
Old Apr 14, 2007 | 11:08 PM
mxs's Avatar
mxs
are you sure they are real Teins, and did they come with directions?
Old Apr 15, 2007 | 07:15 AM
Nochek's Avatar
I ordered them from Procivic.com, they came with the same instructions Tein has on their website, which is a bunch of cautions, and some info on bumpstops.
I couldnt get ahold of procivic, since it was saturday, so I searched the internet, where I found a few DIY's that said put the taller springs in back. so I did, and messed up.
Old May 27, 2007 | 07:28 AM
Blackice's Avatar
i did the same thing with my civic the fronts real high and the back is super low
Old May 27, 2007 | 08:32 AM
jonyg98civicex's Avatar
make sure to post pics of your drop when you get it done properly, cause I am about to buy the illumina/tein set-up or the illumina/h&r sports set up and i want some pics
Old May 28, 2007 | 10:57 AM
Blackice's Avatar
it was actually wat they said the back is crazy high and fron is reaaly low ill take some before and after picks to show yall wat im talking about
