OEM Spring Rates
I have been searching for two days for this information, but i cannot find it anywhere. So i'm hoping that some Suspension pros like Marnie or AJ have this information. But does anyone know the factory spring rates for stock suspension? i'm actually starting to look into getting coilovers and want to have a general idea of how much stiffer they are compared to factory
Suspension, Brakes, Tires & Wheels >> Stickies >> Links to useful suspension information >> Lists of spring rates [8D]
Can't find it for your specific car but I'd bet it's somewhere in this range. Probably closer to the 96-00 Civic rates...
DC2/DB8 212F/117R
96-00 EX 165F/80R
DC2/DB8 212F/117R
96-00 EX 165F/80R
how about a recomended spring rate
ive contacted GC thru email and so far been like i think 2weeks with no responce
i want a medium spring rate... alittle stiffer than stock but still not REAL stiff.....
ORIGINAL: civicexracer
fo shizzle. i'd maybe go for 350/350 for a little less understeer..
ORIGINAL: mxs
The standard ground control rates will be fine, 350/250
my stechs move quite a bit....
http://www.youtube.com/watch?v=AFI-X7UlwnY
also do ya think those GC top hats are worth the money for the extra strut travel?
See i duno what i want, i have a friend with Tein Basic's and they are392/168, and i find them a little too stiff for me. i was thinking like 300/125 or somthing. now to just find somthing like that for a decent price and in a full coilover [>:]
was thinking Ksports, but hell the ones i find for a good price are 560/336[:'(]
ORIGINAL: addiction2bass
what spring rate do you have? and you got any videos of your suspension being bounced manualy? main reason i want a stiffer ride is so i dont have as much travel so maybe i wont have to roll my fenders after i get some slightly larger wheels....
got a quick vid of my car doing what ur doing in ur vid. first 2 parts are of the front and rear on street rebound. the other 2 are of thefront and rear on race rebound. pushing pretty hard by hand and then jumping on the door sill, i weight ~150lbs. the difference between the street and race rebound settings i have arnt very noticable by sight but the feel when driving is very different. also note how low the car is, like i said no rubbing issues.
http://www.youtube.com/watch?v=z2PoN93jao8
ORIGINAL: Fiirkan
EDIT: if ur looking for a comfortable ride, def dont get the setup i have. its rough on the streets for sure, even on what u would think are smooth roads. those smooth roads arnt smooth anymore lol. feel everything...not only is the ride rough, shock life wont last too long. most ppl dont run over 500 in/lb springs on the Koni Sports because their under dampened for those rates. that is the reason why the ride is so rough and also will lead to premature shock failure. i know this and have known this since i bought my suspension. i plan on having the shocks re-valved sometime next year and most likely go to high spring rates.
I may just get the Tein Basics cause riding in the front isn't too bad, it was more so when i was in the rear i found it too rough, but I got a bit use to it after a while. we shall see, if i find somethign for a good price, that has a softer setting i may get that..
Reason for me getting something with adjustability is, it's my DD, and my winter car. so i want to be able to bring it up a bit in the winter for clearence, so i don't get stuck everywhere
