Omni Power Coilovers...
ORIGINAL: Nail I3unny
are you looking at full coilovers or partials?
I've only adjusted mine once so far, but I like the design of the spring perch on the Ground Controls. It's one big threaded ring with a set screw, you just turn the whole perch by hand and then tighten it in place with an allen wrench. not with those two funny-looking coilover adjusting wrenches.
MXS is right, I only need partial coilovers as I already have adjustable shocks. Like MXS mentioned, I also want something that is easy to change settings on. I know the Ground Controls are simple to adjust. I'm going to call about the Omni's adjustment process.
Thanks for the tire info Civicexracer. I saw an autoX event not too long ago and I just got excited thinking about putting my car out there. Looks like a lot of fun.
Well, I've been doing some research and I think I'm going with the Eibach Ground Controls if anything. The main reason is because of the spring rate which will determine how harsh the ride is. I want to lower my ride and increase handling but this is my daily driver and I do not want to sacrifice ride comfort for price that much. Here's what I've found researching multiple coilovers from some of the major brands out there that may be helpful to some others...
These are all for 92-95 Honda Civic applications not sure if it applies to any other models:
Tokico Illumina springs are what I have now (non-adjustable) 253f / 123r
Eibach Ground Control: 350f / 250r
Skunk2: 450f / 336r
Omni Power: 448f / 336r
All these seem to have a substantial increase in rate over my current spring rate. Can any suspension gurus give me an idea of what to expect with an approximate increase in rate of 100 f&r?
Also MXS, what springs did you have on your car before the GC coilovers? What differences in ride comfort have you noticed?
Thanks in advance.
Skunk2: 450f / 336r
Thanks in advance.
Well I went from stock to this. The thing is, at least with the Ground Controls, you can get whatever spring rates you want for another $10 each. Go here: https://www.redshiftmotorsports.com/...ver+Kit+CUSTOM Higher number is stiffer. I got about 300 in the front and 400 in the rear. It's obviously not as comfortable as stock, but I have the shocks at full stiffness too.
ORIGINAL: jake11375
Skunk2: 450f / 336r
Skunk2: 450f / 336r
ORIGINAL: mxs
red2000Si
Jan 25, 2007 12:57 PM
F23AccordLX
Nov 12, 2006 03:02 PM
