Proper Offset (kind of involved)
Old Sep 2, 2005 | 03:24 PM
Dogmeat's Avatar
Default Proper Offset (kind of involved)
Ok..did the proverbeal search and from what I see if I stick between 40-45 I'm safe. Most of the Honda factory rims come 45. I'm curious....If I start to up size and get wider rims should I increase or decrease the offset? I've seen everything from 32 to 48 and inbetween...I just don't want to drop the hammer and get stuck rubbing...I've got a 2" drop
Stock rubber was a
165/70/R13 with OD 22.09 = Stock
195/60/R14 with OD 23.2 = Current and it rubs ocassionally
195/50/R15 with OD 22.68 = first option
195/45/R15 with OD 21.9 = bent rim??...lol
195/45/R16 with OD 22.91 = another hard to find size
205/45/R16 with OD 23.26 = second option
205/40/R16 with OD 22.46 = bent rim??if I can find them (yokohama prada spec II)71.00
So I'd love to go with 16s but I'm not sure the 205 will clear with out rubbing, and 40 series for a daily could end up kinda of a harsh ride with bent rims, and the 195 in a 16 is hard to find special order type tire.
15s...I'd always want to see the 16s in there. LOL
So what do I do? who knows what fits without rubs? Should I get a full front UCA camber and rear camber before anything? Any thoughts would be appreciated, and yes I could stuff 17s in there, but I won't
Old Sep 5, 2005 | 05:31 PM
Dogmeat's Avatar
Default RE: Proper Offset (kind of involved)
So can anyone answer
I'm thinking decrease so the extra rubber is sitting toward the fender, not the inner liner. So instead of a 45 make it a 42 or 40 right??
Old Sep 5, 2005 | 05:42 PM
Chimera02EX's Avatar
40.
Thats the normal offset for 16" rims.
Old Sep 5, 2005 | 05:52 PM
mxs's Avatar
mxs
ORIGINAL: Chimera02EX
40.
Mine are 16x6.5 with 45 offset, they are Honda rims with 205/45/R16 tires and they don't rub.
Old Sep 5, 2005 | 07:55 PM
I think because of the 6.5" width the offset is bigger. Mine are 16 x 7 I believe with a 40 offset.
mousy
Nov 23, 2009 10:15 PM
madeincanada123
Feb 10, 2008 02:56 PM
PhilStubbs
Aug 12, 2007 04:38 PM
Autogeek
Aug 1, 2005 09:16 AM
