question on front suspension alightment i have all the specs
Old Aug 21, 2008 | 01:29 PM
JakeyMan07's Avatar
Default question on front suspension alightment i have all the specs
yes i got an alighmnet like 1 month ago and everything shows that it is in specs or degrees where it is suppose to be. But it all looks good and i put brand new tires on my car so i really dont wanna ruin them but why does my front tires still look like they bow in a little dont look as bad as before but you can still see that the front tires bow in a bit or looks like they toe in. Autotire said you cant see if your car is toe in i got a warranty on my alighmnet. So what do you guys think i should do just keep driving and check my tires to see if they are wearing uneven or take it back and have them look at it. what is weird is that it is all in degrees but still looks like front tires are not sitting even liek they bow in. dunno what to do
Here are my final readings after the alighment:
FRONT
Caster,Left= 3.57 deg.
Caster,Right= 3.21 deg.
Camber,Left= 1.38 deg.
Camber,Right =0.84 deg.
Toe, Left= 0.02 deg.
Toe, Right= 0.03 deg.
Toe, Total= 0.05 deg.
REAR
Camber,Left= 0.21 deg.
Camber,Right= -0.88 deg.
Toe,Left=0.08 deg.
Toe,Right=0.09 deg.
Toe,Total=0.17 deg.
THRUST ANGLE
-0.01
SAI
Left= 9.44 deg.
Right= 9.70 deg.
if you need any other degrees than let me know but i think that should be enough let me know if that is the ok alighment or not thanks
ultrarevvin1
Jan 12, 2014 07:18 PM
caveman1990
Nov 16, 2011 05:15 AM
ricekiller7
Sep 27, 2008 05:48 AM
Mistaashby12
Jul 20, 2008 08:03 AM
nightshader
Aug 8, 2005 05:08 PM
