Rear Brake Pad change Piston reset help.
Old Sep 26, 2011 | 10:32 AM
jmc2011's Avatar
Default Rear Brake Pad change Piston reset help.
Can anyone advice how to reset the piston on the rear calipers after changing pads. Park brake on or off. Clockwise or counter clockwise rotation? Will standard brake caliper reset kit do trick or is there a special honda tool?
Any advice greatly appreciated
Old Sep 26, 2011 | 11:22 AM
02Hatchback's Avatar
1st- parking brake off, 2nd- counter clockwise, 3rd- I bought a cube lookin' thing that went on the end of a ratchet(12$ or so) that had all the different prongs on each side... it worked pretty good, it takes a lil elbow grease tho. haha. Make sure u take the cap off the brake fluid container.
Old Sep 26, 2011 | 12:10 PM
jmc2011's Avatar
Thanks. Thats great. Going to get tool for the job and follow the advice. Probably stupid question but, Why cap off brake fluid container, does that make a difference?
Old Sep 26, 2011 | 12:34 PM
because your compressing the piston, therefor pushing fluid back into a air tight container
Old Sep 26, 2011 | 12:37 PM
jmc2011's Avatar
Thought that was going to be the reason alright. Thanks for advice. Hopefully that has me on the right track now.
Old Sep 27, 2011 | 11:21 AM
jmc2011's Avatar
Ok all, got job done. Had to open bleed to move piston and it ended up being clockwise. Used long nose plier to twist piston, ordered cube thing for next time. Thanks you all for the help. Last thing one of the new pads had to be wedged in while all the others just blonked in easy. will have to have a look at it again and see if it moving freely. It not rubbing on disc at moment from what I can tell. Anyway thanks again
mrtimepa
Jun 20, 2013 08:33 AM
juniorbiscuit
Oct 15, 2010 12:24 PM
GirlwithanSIattitude
Dec 2, 2007 11:27 AM
Little Black Hatch
Apr 18, 2006 06:43 PM
kayak
Mar 25, 2006 10:21 PM
