Rear brakes.
My DX coupe has rear-drums. As we all know rear-drums are totally lame and fade like a poorly-dyed t-shirt. In my line of work good brakes are a must. I'm wanting to know if one of the superior trims(EX, LX) has rear disc, and if a swap would be easy or even possible. The cheapest aftermarket rear-disc conversion I can find will cost me around 1000$, which I don't have.
Find the arms off of an Integra like Agent said. I got mine for $200 and bought new cables and bushings to do at the same time, the only other thing your gonna need is a proportioning valve off of the integra, oh and you have a DX? so you should also check out getting a brake booster off of an EX, Integra, or SI. The EX did have an optional disc brake setup also so if you come across one of those you'll be golden
okay, so i need to acquire rotors, calipers and pads, and the booster off of an si or integra. Is the porportioning valve on the booster, or will i need to pull one off of a junk car?
