rear disc conversion
Old May 8, 2006 | 07:41 AM
thakid's Avatar
Default rear disc conversion
i am about to go to a salvage yard on saturday and i would like to know what car would i have to get the rear disc brakes off of to swap with the drum brakes on a 1994 Honda Civic LX
Old May 8, 2006 | 09:33 AM
StifflersMom's Avatar
Cat Fuсker
Default RE: rear disc conversion
94-01 integra
Old May 8, 2006 | 09:52 AM
riceburner700's Avatar
if you want something really nice and doesnt cost a whole lot for a drum to disk all wheel brig brake kit check out www.fastbrakes.com
Old May 8, 2006 | 02:25 PM
Dogmeat's Avatar
^ uh...what??? How does 1400.00 plus shipping and install compare to 300 pick and pull? New pads rotors etc would only be another 200 tops. He'd be saving darn near 1000 and learning brakes at the same time.
side note...four piston fronts would be trick though.
Old May 8, 2006 | 03:19 PM
i was saying for the rear upgrade to disk is like 600 bucks, so its only like another 150 bucks for bigger everything and brand new... but also if ou dont have a money issue.... kit is like 1/2 the price of like a aem brake kit
Old May 9, 2006 | 07:08 AM
thakid's Avatar
Can any one give me a list of all the parts i will need so i wont have to make 2 trips to the junk yard
Old May 9, 2006 | 07:59 AM
Cat Fuсker
e-brake cables, proportioning valve, complete trailing arms, master cylinder and brake booster.
Old May 9, 2006 | 03:07 PM
Stimpy's Avatar
The bolts holding the trailing arms to the lower arms can be a real pain, bring a sawzall just in case so if you snap the bolts you can cut through the lower arm to get the parts home.
and don't slip and headbutt an I-beam like I did [&:]
Old May 9, 2006 | 04:16 PM
Cat Fuсker
plus get all the bolts you can...because the ones on your car WILL break
Old May 16, 2006 | 05:03 PM
creed86's Avatar
94 delsol si work? i saw this on craigslist on 250 what else would i need? difficultly?
http://boston.craigslist.org/pts/161318441.html
