rear disk brake parts
Old Oct 5, 2005 | 01:30 AM
ahhsimon's Avatar
Default rear disk brake parts
i recently bought a whole set of gsr disk brakes( front and rear rotors, trailing arm, caliber, and brake pads) with 2 ebrakes cable .. u guys know anything else i need
i heard that i need a master cylinder, which is optional
proportional valve (optional)
brake lines (optional)
im not sure what else i need to start on my conversion ...
do i really need to change the proportional valve, master cylinder, and brake lines ?? or its only necessary to give u more braking power. .
Old Oct 6, 2005 | 11:30 AM
Super Mario's Avatar
Default RE: rear disk brake parts
you do need a different master cylinder. I did a rear wheel disc conversion and you need a master cylinder for the brake system you are using, not what yo have, the porpotioning valve in the master cylinder is different and it is an absolute must. Replacing the brake lines are only necessary if you have bad brake lines, broken cracked, leaking. Other than that you are going to be veryy pleasedwith your new brakes. make sure to also get new pads on all four and turn the rotors!
Old Oct 6, 2005 | 01:27 PM
amg6975's Avatar
Somepeople on here would advise just getting new rotars rather than turning them. Check www.buybrakes.com.
Old Oct 6, 2005 | 04:28 PM
StifflersMom's Avatar
Cat Fuсker
Prop valve is a must. Get some braided steel brake lines...
Old Oct 7, 2005 | 03:02 AM
ahhsimon's Avatar
but i heard fromy my cousing that he didnt change any of it and instead he just slapped on the rotors with break line and it works ?
Old Oct 7, 2005 | 03:11 AM
ngoti 8tor's Avatar
ORIGINAL: ahhsimon
Sure, you can get it to work with your stock master cylinder, but will it work properly when you need it most?
Your brakes aren't something to skimp on dude! If you're going to mess with them, do em right.
PhillipBurch
Apr 7, 2009 10:08 AM
EJ8_Man
Feb 23, 2008 01:12 PM
urtoslo
Nov 5, 2007 08:23 AM
TeamExodusPres
Feb 5, 2007 05:29 PM
ahhsimon
Jun 14, 2006 09:52 AM
