Rear Disk Conv.
Hey guys,
I'm new to the whole honda tuneing, but I've just bought a 1995 Civic Coupe. I'm building the car to race in SCCA, I've pretty much planed everything thing out. Down to the b20 ( Non-Vtec ) Swap to sus. set-up ETC. The main problem I've came up to the the rear disk conv ( Drum rear ). I've been told i can do a swap from a integra? Is this the most common? Or is there a better way? Any other idea's would be great! Thanks for the help! -Nick... |
yup that is the most common, search around i'm sure you'll find lots of info about a rear disc brake swap from an integra
you can get them off an integra or si civic you need the trailing arms and everything hooked to them and a 40/40 proportioning valve and a couple of new 18" brake lines.
Check this thread it has a lot of information about the swap. https://www.hondacivicforum.com/foru...ad.php?t=78803 If you need more information I can try to point you in the right direction. I am working on converting my HX right now. Putting all the pieces together any way.
u should do a crvtec
(b20 wit vtec head) |
