shocks going bad?
Old May 20, 2005 | 04:46 AM
ahhsimon's Avatar
Default shocks going bad?
i just slapped on some new tokico illumina's adjustible shocks on some max speed adjustible coilovers, with a 2.5 drop back and front, my brother say its stupid cause of the coilovers.. or something it mite blow the shocks... but hten again all shocks will blow eventually but is this set up really bad?? i need some commentaries and .. how long do u guys think my shocks will last.. and do the wear depend on how i set the settings of the shocks?
Old May 21, 2005 | 12:41 AM
sacicons's Avatar
Default RE: shocks going bad?
shouldnt be too bad. did you remove the bumpstops? or cut them down?
Old May 21, 2005 | 04:01 PM
ahhsimon's Avatar
i left the old bumpstop there even though i had new ones because they were still good ? and um .. i left 2 in there?
Old May 21, 2005 | 04:44 PM
sacicons's Avatar
and none in the other 2? w/o bumpstops, the shocks will not last long at all.
Old May 21, 2005 | 06:27 PM
ahhsimon's Avatar
no no.. u misunderstood wat i said lolz .. i have 2 new bumperstop but i left the stocks one there cause it was still good and htere's 2 bumper stop per shocks
Old May 21, 2005 | 08:04 PM
sacicons's Avatar
oh ok. your shocks should be fine as long as you keep the bumpstops in. you may want to cut them down if the ride seems abnormally rough. take about half an inch off of the small end. about one segment.
Old Jun 2, 2005 | 03:18 AM
ahhsimon's Avatar
would any problem occur if i dont cut the bumpstop, to let u know i didnt cut any of my bumpstops at all from front to rear
Old Jun 2, 2005 | 07:50 PM
bleedhondos's Avatar
this is probably a stupid question where and what exactly is a bumpstop?
Old Jun 2, 2005 | 08:04 PM
Nail I3unny's Avatar
isnt it a piece of rubber or poylurithane that stops the axle from hitting the chassis when the suspension compresses too much?
Old Jun 3, 2005 | 01:01 AM
Kappa22's Avatar
That (on some cars), and it keeps the struts from bottoming out, which puts a loooot of wear on their internals.
