Spring Install
Hey Ya.... Imma bout to get my tein s tech but was just wondering what the going rate at mechanic shops is to install them? I have heard around $50 for each one....kinda pricey I think...
Is it something that one can do them selves?
i've heard its easy to install springs and that prolly the hardest thing to deal with is the spring compressor. do a good amount of research and get some friends to help u out, best if atleast 1 of them has done them before.
I'm just finishing up a spring/suspension replacement on my 94 Civic and would be more than happy to help you through it. Also, if you can give me your year/model of car I may be able to get you a manual and e-mail it to you to help you through it...
Also, as was previously stated the most difficult thing to do is the spring compressor, you can usually rent a decent one from an auto parts store, or pull your shocks/struts off and take them in with your new springs and get the new springs put on for a lot cheaper than having them do all the work... I've done mine a couple of times and got caught in a dire emergency once where I couldn't do it myself and had to pay to have it done. I paid $250.00 to have it done...
Thanks to all of you for your reply..I have a 98ex sedan..Yea my cousins says he can help and he has done it to his old protege so I guess it should be pretty similar....
ORIGINAL: sir_nasty
...make sure when you borrow the spring compressor, that it is aftermarket spring compatible. The "hooks" on the OEM compressor they gave me didn't fit into my aftermarket springs.
I wouldnt exactly call it a "straight forward easy install," but I think if you're fairly handy with a wrench you can handle it. Read through THIS THREAD to get an idea of a common problem you're likely to run into.
Good luck!!!
Good luck!!!
