springs only?
i was wondering if i could go with some eibach springs on stock shock and all that other stuff just stock and go with JUST springs. Is that possible without having to do new shocks and dampers and stuff?
LATA!!!! |
RE: springs only?
It would be a good idea to get a camber kit, and depending on the drop, new shocks as well. If the drop is pretty low (2 inches or more) your stock shocks will blow pretty quick.
RE: springs only?
what about a 1.75 in. drop will that shocks be able to handle that?
RE: springs only?
The lowest car ive seen on stock shocks is a 1.8 drop, and his shocks are still doing fine, i dont know how much longer they will be fine.... How old is your current setup?
RE: springs only?
i just got the car like a month or 2 ago but it's 96? if that helps.
RE: springs only?
Honestly man, save yourself the trouble later on and get some new shocks. You may also wanna pick up a camber kit.
RE: springs only?
i can;t find a camber kit, where can i find one?
RE: springs only?
What cant you find???
And if you just wanna buy springs, get some tein s-techs. You can keep everything stock with those. Its a 1.5 inch drop i believe. |
RE: springs only?
oh and thank's for the help dude.
lata!!!!!!!!!! |
RE: springs only?
^^a camber kit
