steering wheel vibrating
Old Dec 3, 2008 | 11:46 AM
zoom24's Avatar
Default steering wheel vibrating
maybe smeone here knows the problem im experiencing with my 99 civic ex. when im driving at a speed of 50mph and up, when i step on the brakes lightly the steering wheel starts vibrating. i was thinking maybe the pistons needs some cleaning, balancing or alignment. im not sure, so maybe someone can give me some pointers on this issue. thanks in advance.
Old Dec 3, 2008 | 12:23 PM
My04Civic's Avatar
Administrator
you recently change your brake pads? Im gonna say it is a warped rotor or 2. I just had the same issue. Rotors changed, no more shaky shaky.
Old Dec 3, 2008 | 03:51 PM
--drew--'s Avatar
also, your car could need a wheel alignment
i had the same problem
went to my local tyre place and got a wheel alignment done and it was perfect
Old Dec 3, 2008 | 07:15 PM
ltkenbo's Avatar
I had the same problem but it was both of those. First of all the steering wheel would start vibrating just when driving fast without braking but then I got it aligned so that stopped but since my rotors are warped, when I break on the freeway it shakes horribly, its actually kinda scary.
Old Dec 3, 2008 | 09:00 PM
dito... if it shakes when you break then definatly warped rotors......
Old Dec 8, 2008 | 04:30 PM
herman's Avatar
Hey new to the forum but check and remove all the rust behind the rotors when putting new on and get a good rotor not just cheap white box ones BIG difference
good luck
Old Dec 11, 2008 | 09:33 PM
ghosttech's Avatar
I had a similar problem you should check the tie rods on your car thats could be the cause
Old Dec 17, 2008 | 11:30 AM
conceptualpolymer's Avatar
Your rotors need to be turned (machined) or replaced (if they would be too thin after being machined).
jpnolan
Apr 14, 2009 11:11 AM
runswit2guns
16
May 30, 2008 06:29 PM
Mark
30
Nov 12, 2005 05:18 PM
mahmi
Jul 25, 2005 04:54 PM
magnetic blue
Apr 9, 2005 05:00 PM
