Strange sound after tire rotation
Old Dec 14, 2005 | 07:46 PM
Toppers's Avatar
Default Strange sound after tire rotation
Bah, I knew rotation was for suckers. I've never rotated tires in my life, but decided to just this once. And now I'm getting this strange noise coming from the front end near the wheels/suspension. Almost like a steady vibration as I get up to speed, and coast down to a stop.
This sucks, I should have left well enough alone..used to put 50k+ on a set of tires and never rotate them once.
Old Dec 14, 2005 | 07:57 PM
mxs's Avatar
mxs
Default RE: Strange sound after tire rotation
silly question, but... are they directional tires?
Old Dec 14, 2005 | 08:30 PM
Toppers's Avatar
I don't know, that's what I was wondering too. They just swapped front to back directly, so as far as I know, were put back in same direction they came off on.
Old Dec 14, 2005 | 09:41 PM
amg6975's Avatar
Check the pressures. The rear tires should be less inflated than the front. See if they're worn evenly, your rear alignment may be off.
Old Dec 14, 2005 | 10:07 PM
Toppers's Avatar
Ok, will do. Would installing the 4-piece strut bar set recently have anything to do with this? It started around the same time.
Old Dec 14, 2005 | 10:11 PM
mxs's Avatar
mxs
check all the connections. check your lug nuts. did you torque everything to spec?
Old Dec 15, 2005 | 07:13 AM
Toppers's Avatar
I didn't, but supposedly they did. I'll check again.
Old Dec 15, 2005 | 12:24 PM
trickyvick's Avatar
FWD cars are notorious for "cupping" the rear tires.....how long were they on the rear before you rotated them. This uneven tire wear is a result of the rear struts/shocks allowing the tires to bounce some......you may have waited too long to rotate them and the best thing to do is to put them back and wear them out......good luck!
Old Dec 15, 2005 | 12:54 PM
mill$civic's Avatar
i dont think its this...but you no how you sead you can feel it viberate when you start going to a stop..well my friend had the same thing with his car and it was because the lug nuts were loose
Old Dec 15, 2005 | 06:04 PM
ngoti 8tor's Avatar
You might need to get them rebalanced.
Capnx
Dec 17, 2011 04:33 PM
Motor35
13
Jan 29, 2009 11:23 AM
pcgmr
Jul 20, 2006 09:53 PM
skytanker2003
Dec 14, 2005 11:00 PM
skytanker2003
