strut bar questions
Old Dec 7, 2007 | 06:46 PM
Default strut bar questions
just wondering where each of these strut bars would be installed and how before i get any of these. which of these should i get. Front strut bar, rear strut bar, lower tie strut bar, frontstrut tower bar. after i install these would i need to do alignments? or do i just install. any one have any stories about the ebay strut bar?
Old Dec 7, 2007 | 06:50 PM
Default RE: strut bar questions
ebay ones work just fine...
i know at least for the UPPER braces you dont need any type of alignment afterwards... tho im not sure about the lowers cause i havent used them yet... uppers are VERY EASY TO INSTAL... just 2 nuts removed from the tops, pop the strut bars ontop of those strut nuts and just put the nuts back and tighten them down.... and just remember to tighten everything down and your golden...
Old Dec 7, 2007 | 07:02 PM
is this one good ... http://cgi.ebay.com/ebaymotors/96-97...spagenameZWDVW... or could you find a better, inexpensive one. thanks
Old Dec 7, 2007 | 07:20 PM
which of these would be better because the grip part looks different
http://cgi.ebay.com/ebaymotors/Honda...spagenameZWDVW
OR
Old Dec 7, 2007 | 08:00 PM
civicexracer's Avatar
ORIGINAL: sfazngiants
OR
the first link is the rear strut bar. the second link is the front strut bar. would be cheaper to buy the full set insted of buying them seperatly.
http://cgi.ebay.com/ebaymotors/92-00...QQcmdZViewItem
Old Dec 7, 2007 | 10:17 PM
would it be effective if i just run a front upper strut. see a lot of people just running the front upper strut.
Old Feb 2, 2008 | 08:27 PM
PDthree!'s Avatar
i kno this is a dumb question.. but what exactly do strut bars do?
Old Feb 2, 2008 | 08:57 PM
that_guy5's Avatar
lessens body roll when turn and such
Old Feb 2, 2008 | 09:21 PM
mybrokenblinker's Avatar
ORIGINAL: that_guy5
FALSE
It makes the chassis more rigid so that the suspension can do what it was designed to do with less chassis flex.
Old Feb 2, 2008 | 09:35 PM
PDthree!'s Avatar
alright thanks.. sharper turns and such?
