strut bars and h-brace
i have a stock suspension and i was wondering if a front strut bar and a rear upper and lower strut bar and an h-brace would give me better performance....
im looking for something cheap and easy to install that will help out with suspension...any suggestions would be nice
thanks
thanks
assuming you mean rear upper and lower, and front upper and lower here ya go... The one under the hood is cake, just make sure you have a torque wrench and torque the bolts to spec. The trunk, same story, only theres a little carpet cutting to be done, no biggie at all. Rear lower is a little harder, as these bolts are a lot bigger. The front lower, is a pain in the ***. I had to rebore the brackets on mine to fit, cause the one i got didnt fit the bolts down there. With most kits designed for your vehicle, you wont have this problem, but mine were cheapies off e-bay, so a "perfect fit" was a long shot. Anyway, if you need any help along the way post up, or PM me and i'll guide you through it
ORIGINAL: mill$civic
impact gun would make things alot more easy if you can get to one, but you will really feel the differece when you put them on, good mod
does the rear upper strut brace realy help? or would i probably not feel it?
i just got my upper front and rear braces since it was only alittle bit more for both on ebay
ya im cheap....
but i threw on the front brace realy quick and WOW shocked how much it realy helped...
BUT unfortunatly my subbox is in the way for the rear brace currently..
if ya guys think i could realy feel a difference like in the front then ill move stuff around and make it fit... and build my next box around it.
ya im cheap....but i threw on the front brace realy quick and WOW shocked how much it realy helped...
