suspension question
suspension question
alright, i just purchased new coilovers and struts and im going to install them here this weekend and i was wondering, if the original stock struts and springs are one unit, meaning can i take the strut and spring off the car without the spring decompressing and flying off the car
RE: suspension question
you can take the strut assembly out of the car without a compressor, but to dissassemble it you need a spring compresor, because you will need to reuse the upper strut mounts and a few other things. good luck and be careful.
autozone u can borrow a spring compressor. just go in and ask to loan it. they will take a deposit down of like 20 bucks or something and then when you bring it back they give you your money back.
yeah i have my own spring compressor, and just needed to kno if i had to compress the spring while it was on the car or if i could take it out of the car and then compress it, what are all the parts that i will be reusing that are currently on the stock suspension?
thanks for ur answers
im not totaly sure of all the parts you need, but the upper strut mounts (the black part on the top of the spring) will be reused. you can get away with out using a spring compressor at all if you remove the nut holding the strut together while the car is still on the ground, but im not sure how much easier that will make the struts to remove, if at all.
reinstalling the rear struts is a lot easier if you can use the compresor, otherwise you will have to unbolt the trailing arm and force it in. i know ive done it more than a few times.
thanks for all the answers, now what i got from summit was kyb gr-2's and matrix coilovers, has anybody had any experiance with these products and if so how did you like them or any problems you had with them
ORIGINAL: 98 EJ8
You will need to uncompress the spring once it's out as well. just be careful to do this....compressed springs if they snap can kill someone or seriously injure someone if they are taken off unevenly and it just springs off the compressor.
well i started my suspension today, and most of you were right, i didnt have to compress the spring while it was on the car, now since they are coilovers im unsure of how much i should drop the car, any suggestions on what you guys think the optimum ride height is?
