tein stech
Old Jan 8, 2006 | 03:05 AM
97_nw's Avatar
Default tein stech
my friend is about to buy some stechs, but hes on a budget. before he buys them, do you think they will be able to run fine on his stock shocks beccause of the lower spring rate? hes just a daily driver, and its a 95' accord.
Old Jan 8, 2006 | 09:37 AM
Chimera02EX's Avatar
Default RE: tein stech
The S-techs will run on the stock springs, but when your buddy gets the money he should get some Tokicos or KYBs.
Old Jan 8, 2006 | 11:18 AM
BallardCivic's Avatar
Like Chimera said, for a while the car will run fine on the stock shocks, but eventually he will want to move up to bigger and better things. Im personally a fan of Tokicos.
Old Jan 8, 2006 | 04:30 PM
^ +1 on the Tokicos.
Old Jan 9, 2006 | 06:24 PM
Kappa22's Avatar
ORIGINAL: Chimera02EX
Old Jan 9, 2006 | 08:19 PM
sacicons's Avatar
ORIGINAL: Kappa22
+1
Old Jan 10, 2006 | 12:57 AM
x2100's Avatar
Does that mean that the stock shocks will get stressed out from lowering and won't work anymore?
My Tein S-tech springs are being shipped now and on the report it says that the package weighs 1 lbs. Are they that light?
Old Jan 10, 2006 | 04:50 PM
Kappa22's Avatar
Nooo. They probably weigh 20 to 30 lbs (depending on whether or not they're progressive, which I believe S-Techs are).
As for lowering, yes, it will put extra stress on your stock struts, since they're not designed to damp that much. They'll last pretty long on S-Techs though, since they're relatively tame as far as lowering springs go.
Old Jan 10, 2006 | 05:54 PM
Make sure you aren't driving like an *** whipping around turns and such, you could bust a shock.
Old Jan 10, 2006 | 09:27 PM
mill$civic's Avatar
a set of tein s-tech will run you about $160 and its like a 1.8 drop but they work with your stock shocks and you dont need a camber kit..here are 2 links from people that have already installed them on here, myself and mynmisoli ... < i have this typed out already because so many people ask the quesion
https://www.hondacivicforum.com/m_123028/tm.htm
https://www.hondacivicforum.com/m_69.../tm.htm#107781
