tie bar cross thread :(
i installed the passenger side of the rear tie bar just fine but i got to the drivers side and it all when fine till i started wrenching in and ended up cross treading. i was removing it but its now jammed. halfway screwed in. when im done fixing the front end from my wreck should i drive it to a shop?(is it safe?) or what?
RE: tie bar cross thread :(
bump
prolly not very safe...if u messed up the threads u'll prolly need a new strut mount..
strut mount? this doesnt have anything to do w/ the struts. i tried an impact wrench, didnt go in so i have to remove the bolt w/ a breaker bar and try putting it back in. i kno that i bent the lil bolt out of place so im gonna take a hammer or something and put it back. its just hard doing it under a jack stand. so im gonna take it to a shop. this guy quoted me 40 bucks for the front and back tie bars, ima go there and ask him to do it.
gona take some pix to show u wat i mean |
which one is it 1 or 2? if its the bolts for 1, u'll need a new mount, thats wut those screws are, they connect to the strut, hold the spring on, and is wut connect the suspension to the car. if it's 2 then just cut it off and buy a new bolt.
[IMG]local://upfiles/4748/08B7A057BC564CC8BEC6117E96AB4B88.jpg[/IMG] |
2 Attachment(s)
sorry i didnt specify. im talking about the rear lower bar
passenger side. went thru all the way just fine Attachment 39616 drivers side. see it wont go all the way thru. can u notice the bend in the nut? Attachment 39617 |
yup that looks crossthreaded-- just bust it off & get a new nut & bolt
Yea you should be ok for the time being but I'd try and get another one.
i dont think that nut comes off its on the car forever. it like welded to the car. So u would have to get a thread restorer and rethread the nut and then buy a new bolt.
ill just take it to a shop and have them cut out the current peice and weld in a new nut
