Tire help
Hey does anyone know what a good tire pressure is for a 205-40-17 tire is? Thank you!
RE: Tire help
it depends on the tire. look on the sidewall, it should say the max pressure on it somewhere. go about 10 psi lower than that, but not lower than about 32-35 psi.
RE: Tire help
i have 17-205-40 tires and i use 40 psi.
RE: Tire help
sounds about right.
RE: Tire help
Tire pressure is one of those things that depends on what application it is on. If you are at the track you might want to run mid to high 20's for psi. But for casual driving you would want to run 30-38psi.
