Tire help
Old May 13, 2005 | 11:41 PM
94VTECoupe's Avatar
Default Tire help
Hey does anyone know what a good tire pressure is for a 205-40-17 tire is? Thank you!
Old May 14, 2005 | 12:10 AM
sacicons's Avatar
Default RE: Tire help
it depends on the tire. look on the sidewall, it should say the max pressure on it somewhere. go about 10 psi lower than that, but not lower than about 32-35 psi.
Old May 14, 2005 | 04:24 PM
blackeyes's Avatar
i have 17-205-40 tires and i use 40 psi.
Old May 14, 2005 | 05:18 PM
sacicons's Avatar
sounds about right.
Old May 24, 2005 | 04:03 PM
DT Precision Tuning's Avatar
Tire pressure is one of those things that depends on what application it is on. If you are at the track you might want to run mid to high 20's for psi. But for casual driving you would want to run 30-38psi.
kjsayers
Jun 10, 2010 10:06 AM
2002coupe
Feb 27, 2006 08:35 PM
rpinoh1
Feb 13, 2006 02:12 PM
THE_CRIPPLER
Sep 9, 2005 10:32 AM
blacksilver88
Feb 15, 2005 09:45 PM
