tire pressure monitoring devices
because our 08 cr-v has a factory tire pressure monitoring system, i wanted to have one for my civic. after searching, i found ones at tirerack.com and purchased the ones from orange electronics.
the local tire shop broke the wheels and installed the valve stem/sender units and i found a good place on the dash for the gauge. it shows the pressure of each wheel and the temperature (at the push of a button). all in all it was a good investment-i can see the pressure of each tire with a quick glance. they are very accurate, too. |
I'm kinda spoiled with the factory setup in my 01 Corvette. The digital readout that is built into the dash, directly in front of the steering wheel can display each tire's air pressure, as well as battery voltage, coolant temp, oil temp, oil pressure, miles to empty, instantaneous mpg, trip miles (A and B), and all engine, steering, and brake codes. I keep the oil temperature displayed as a default.
But yes, everyone should have a tire pressure, as well as an ambient temperature readout. |
i don't really like those monitors... they're kind of annoying.
like in my girlfriend's nissan sentra, the light came on saying the tires were low... so her dad checked them and they were fine. so now there's this annoying light stuck on. she says it doesn't bug her... i don't see how. warning lights on the dash bug the hell out of me if they come on. |
My warning message doesn't come on unless the pressure gets down to 24 psi. If your girlfriend's monitor is falsely reading pressure, have the monitor kit replaced if the tire pressure gauge you are using is really accurate (check with another gauge, first). There's no need to drive around with a false warning light displayed.
(Post 590574)
On some cars, such as nissans and some fords, they need to be reset using a special computer tool. The tools basically reprograms the sensors and you have to do all four at one time.
i'll look for a reset button tomorrow when i ride with her to school
how do I reset the TPMS light on my 09 CVivui. had a new sensor put in rt. front wheel'
Originally Posted by pepsi bob
(Post 797099)
| All times are GMT -8. The time now is 10:29 PM. |
