tire rub
Old Sep 17, 2006 | 03:30 AM
I EM 2 4DR.'s Avatar
Default tire rub
Has anyone tried an EM2 ('05 4DR.) with 225/40R17 tires on +40mm offset rims, lowered 1.5"? Wondering if I will have tire rub problems after lowering my car 1.5"?
Old Sep 17, 2006 | 09:23 AM
Nail I3unny's Avatar
Default RE: tire rub
205 is the widest tire you can run and not rub without fender modifications.
Old Sep 17, 2006 | 01:31 PM
Nail,
Are you speaking from experience with an EM2?
Old Sep 17, 2006 | 01:48 PM
civicexracer's Avatar
i dunno from experience but i'd think u'd rub with 225...205's should be alright.
Old Sep 20, 2006 | 08:37 PM
coronakid's Avatar
I have 215/40/17's on an 01 LX and I do not have any tire rubbing. Thats with Tokico and Tein Springs.
Old Sep 24, 2006 | 11:51 AM
MWE's Avatar
MWE
ORIGINAL: I EM 2 4DR.
I claim no expertise with Honda suspensions (I am here trying to sort out a few things for muy wife's '96 Civic and the '07 Civic she is buying), but I have some experience with VWs and BMWs (both street and track). Both are set up with coilovers and adjustable camber (plates in the front and adjustable control arms in the rear). So, some general thoughts: the actual width of a 225/40-17 will depend on several factors. The particular brand of tire (some are wider, some narrower), inflation (obvious) and the specific wheel used. It's not a lot, but a wider width wheel will typically generate a wider actual patch and section width. Most of the tire manufacturers have pretty good spec sheets online that can help you understand what to expect. Front camber will also impact fender clearance; adding a half degree of negative camber can do a lot. Also, you did not mention how much spring rate you are adding as part of the lowering process.
chandler583
Jul 19, 2009 08:47 PM
civicHBjunkie
May 29, 2006 11:45 PM
emooheo
Mar 17, 2006 02:24 PM
Liebers
May 4, 2005 11:43 AM
cage2b
Apr 17, 2005 11:55 PM
