tire rubbing
Old Nov 28, 2007 | 10:08 AM
blackmetal619's Avatar
Default tire rubbing
do camber kits help with rubbing?
my tires rub if I make a U turn
Im scared because my stock tires are rubbing, and once i put my bigger tires and rims on, i dont want it to be rub
Old Nov 28, 2007 | 10:16 AM
Pete's Avatar
Default RE: tire rubbing
stock tires should not be rubbing. What size are they?
Old Nov 28, 2007 | 10:21 AM
mxs's Avatar
mxs
Need more info on your suspension setup, tire brand/size, wheel size/offset, alignment settings
Old Nov 28, 2007 | 10:32 AM
Koni Yellows
H&R Sport Springs
Stock tires with steelies
185/65/14
Old Nov 28, 2007 | 10:33 AM
basbal123's Avatar
yeaa same here you just cant turn your wheel all the way around just let off like 1/4 turn wont rub at leat for me it doesnt
Old Nov 28, 2007 | 10:37 AM
damn.
my car is wayyy lower than expected, I love the way it looks, but i want it to be as low as possible without rubbing
Old Nov 28, 2007 | 11:01 AM
mxs's Avatar
mxs
did you have it aligned after you dropped it, and what were the results?
WHERE exactly is it rubbing? You will probably have to remove the front wheels and look for wear marks.
What are the specs on your new wheels/tires?
Old Nov 28, 2007 | 11:31 AM
no it hasnt been aligned yet, not until everything else is finished.
The wear is on the edge by the top inside of the fender.
new tires are 205/45/16
Old Nov 28, 2007 | 12:23 PM
Littlehag's Avatar
My 18's rub when I turn the wheel all the way. Just avoid turning it really far, and if you have to... well, too bad.
Old Nov 28, 2007 | 12:33 PM
mxs's Avatar
mxs
ORIGINAL: blackmetal619
if the top of the tire is rubbing on the outside of the wheel well (and ONLY there) you may need MORE negative camber... it's hard to say for sure though without knowing the current specs... what else do you have to install before you get an alignment??
you still haven't answered all of my questions [8D]
ps. I have my Civic lowered way more than yours, my stock 14's don't rub at all, 205/45/16s only rub slightly at full lock
