Tire rubbing
Old Jul 9, 2009 | 12:05 AM
CrunchyToast's Avatar
Default Tire rubbing
Ok,
Since I had the car, whenever I turned to the left the rear back tire would rub on the fender. Recently I had my tires changed and now it rarely happens on the right and only occurs on the left now, which it never had.
At first I thought that maybe while the car was up, the spring came out of its pocket so I lifted the car and the springs were both in the socket. I don't know what could have happened because I watched the tire change the whole way through and they did nothing to the car that shouldn't have been done.
I don't know my tire size right off hand so if you need them, I can run downstairs and check them. They're all the same size lol
Maybe my shocks are bad? I was thinking of replacing them, but don't know if its worth it right now if the problem doesn't become resolved after the change.
Any help is appreciated .
Old Jul 9, 2009 | 01:10 AM
Need more information about your car.
1. Is it a Civic?
2. What year is it?
3. What body style?
4. Is it lowered?
5. Are they stock wheels?
6. What's the tire size?
Old Jul 9, 2009 | 01:41 AM
Seeing as this site is called "Honda Civic Forums" I didn't think about putting it is a civic.
'98 Civic EX Sedan (4 door), not lowered, non stock 205/55R16.
Old Jul 9, 2009 | 01:32 PM
You'd be surprised.
And that's why. Your tires are too big. Recommended tires size is 205/45/16. Your sidewall is 20.5mm too tall, making your overall diameter of the wheel + tire 41mm too big.
Old Jul 10, 2009 | 09:55 AM
So then if I went and swapped out for 45R16 it would be just fine and would still fit my wheel without rubbing correct?
Old Jul 10, 2009 | 01:20 PM
Should be.
Old Jul 10, 2009 | 03:31 PM
or you could always roll your rear fender lips.
or if you have those rubber inner fender covers you can just pull those off the rear lip if its just verly rubbing and you have them.
but those tires are just not the right size. not only are you rubbing but your speedometer is also being thrown off if your going 60MPH on your gauges your really only going 56.5mph
if you just got those tires new then i would take it back to the tire shop and tell them they gave you the wrong size and you want the right size for your car!
if you want to check tire sizes use this site that is very helpfull
http://www.1010tires.com/TireSizeCalculator.asp
Old Jul 12, 2009 | 10:05 PM
KarTuneMan's Avatar
Oh my Lord.... You do NOT need to roll your fenders. EVER!
Get the correct fitment on the wheels, and life will be good.
Offset, offset, offset, offset.
Old Jul 13, 2009 | 05:31 AM
ya you do. unless your using stock wheels. with a lowered vehicle and wider wheels they just wont clear the rear.... UNLESS you like negative camber. tho myself i think it looks very bad in the rear.
Old Jul 13, 2009 | 07:40 AM
Rolling the fenders is just a band-aid. It doesn't fix the actual problem. Besides, if your car sits like my old ej1 did, even with the stock wheels, and you didn't have negative camber, the tires would still rub.
Negative camber is functional; it helps with stability during turns.
Rolling the fenders is not.
