Tire size help on gsr blades
Old Jul 17, 2009 | 06:24 AM
beaudan1's Avatar
Default Tire size help on gsr blades
I have a 96 hatch lowered on skunk springs 2.5 front 2.0 rear. just picked up some blades last night and they need tires, so my ? is will 205/50/15 rub or should i go 195/50/15? any help would be great. Thanks for your guys time.
Old Jul 17, 2009 | 02:30 PM
Well first you need to lower it more... I keed, I keed
I don't believe either should rub, but you'd have less of a chance of rubbing with the 195's. What's the width on the blades, anyway? 205 seems like a wide tire for stock honda wheels.
Also, are you running negative camber or did you get camber kits? If you run a little negative camber (I don't see 2.5/2 creating more than -2 degrees of camber which won't hurt anything) you'll have even less of a chance of rubbing.
Old Jul 17, 2009 | 10:01 PM
I would go with 195/55/15. 205/50 has a chance of rubbing.
Old Jul 18, 2009 | 10:55 AM
beaudan1's Avatar
i have no camber kits. i just couldnt wait to put the blades on so i got 205/50/15 last night and mounted them at work this a.m no rubbing isues at all. thanks for your anwsers guys.
taovang
Feb 20, 2008 12:30 PM
SpanishFly21
Oct 29, 2006 12:20 AM
deverse
Apr 5, 2006 04:01 AM
allvtec22
Oct 18, 2005 08:39 PM
john9i6
Feb 3, 2005 08:05 PM
