tokico help
Old Nov 11, 2006 | 05:33 PM
ic892003's Avatar
Default tokico help
have a 92 civic 4dr sedan with 17 inch rims with low profile tires. want to drop maybe a 1.8 inches, thing is i dont know shyt about suspension. if i get tokiko shock absorbers, wut else will i need to go with it lowering springs? camber kit? not sure help please !!
Old Nov 11, 2006 | 05:45 PM
TheMoogly's Avatar
Default RE: tokico help
You answered your own question, congrats!!! Yes you'll need the struts, springs/shocks, cambers AND an alignment!
Old Nov 11, 2006 | 05:53 PM
ic892003's Avatar
woooo hooo!!!! yea i new i was thinking right lol, so wait lets say i got tein s-tech lowering springs ans put them on with ym oem shocks, chances are my shocks will go correct???? and last if i do just get the stech lowerignn springs will i also need cambering kit, struts and/or alignment?
Old Nov 11, 2006 | 06:57 PM
drbyers's Avatar
get an alignment no matter how low you take your car.
$60 for an alignment now, versus $200 and up for a set of new tires later is always better.
Old Nov 11, 2006 | 08:01 PM
TheMoogly's Avatar
If you're going to drop the car more than 1.5 you will NEED after market shocks... your stock ones will die a miserable and early death and cause danger to you and your passengers.
Old Nov 11, 2006 | 09:10 PM
ic892003's Avatar
will i need struts and a camber kit as well?
Old Nov 11, 2006 | 11:45 PM
TheMoogly's Avatar
Yes... like what you typed before... You can get a full coilover kit that is fully adjustable... As long as you have a camber kit you can set a height you want and just get your car realigned and you're good to go.
I never hear anything bad about a full kit... except that they are expensive... but if you're piecing it together you'll probably get the same price anyways!
Old Nov 12, 2006 | 01:01 AM
mxs's Avatar
mxs
^^ I disagree with you, plenty of people here run Teins and OEM shocks with no problems. Where are you getting this magic 1.5" from?
you don't NEED a camber kit for a drop that small. But any time you take your suspension apart and put it back together, you should get an alignment, to make sure everything is in spec again.
Old Nov 12, 2006 | 01:09 AM
civicexracer's Avatar
u should start considering a camber kit if u go lower than about 1.75". alot of ppl with the tien stechs, which are appx. a 1.75" drop, do not have camber kits and are just fine. if u do go that low or lower, u'll prolly want/need new shocks. when lowered, get an alignment. some places offer free lifetime alignments so if something happens, like u hit a bad pothole and it knocks ur alignment off, u can just go there and get it done real quick.
Old Nov 12, 2006 | 01:14 AM
mxs's Avatar
mxs
pick your alignment place carefully... once you're lowered your car might not make it on the lift at some shops.
