What would give me better cornering ability?
Old Jan 31, 2007 | 09:01 AM
96civichb's Avatar
Default What would give me better cornering ability?
I'm Trying to decide between a front strut brace and lowering springs (about 1.5"). Any advice would be greatly appreciated.
Edit: My car is NOT as low as it appears in my sig. That was chopped. haha. My springs are stock.
Old Jan 31, 2007 | 09:08 AM
mxs's Avatar
mxs
Default RE: What would give me better cornering ability?
front strut tower bar is not going to do much on its own. springs and a rear swaybar will help with cornering much more.
Old Jan 31, 2007 | 09:16 AM
werd^ Or, if you're on a super tight budget. Get a full set of strut bars off ebay, I definitely noticed a difference when I did that
Old Jan 31, 2007 | 09:22 PM
Kommando's Avatar
If you already have good tires and rims, I'd go with f&r strut braces, and then a beefier anti-swaybar setup. You would noticeably improve your cornering, while keeping your ride and ground clearance fairly similar to stock.
Old Jan 31, 2007 | 09:59 PM
sacicons's Avatar
my vote too goes to a decent set of sway bars. they will improve your conering and handling feel more than anything except maybe really good tires.
Old Jan 31, 2007 | 10:19 PM
drbyers's Avatar
front strut tower bars aren't gonna help you corner better. those help resist chassis flex up front.
a thicker rear sway bar is the answer. 22-23 mm for the rear will flatten your cornering out like a ****. but it will also induce oversteer, which is kinda scary for noob drivers.
Old Feb 1, 2007 | 03:34 AM
TheMoogly's Avatar
I have Tenzo upper front and rear struts and they tightened things up a bit, but the suspension is going to make the biggest difference when I do it.
Old Feb 1, 2007 | 08:53 AM
96civichb's Avatar
thanks guys. and yes i have toyo's wrapped on 17's. So my grip is good. I've been researching rear sway bars and they're suprisingly cheap. but thanks for the advice guys.
Old Feb 1, 2007 | 01:12 PM
dblclutchin's Avatar
I havn't been able to find rear and front sways for under like $275. i wanna replace the front and rear sways and the rear andfront upper struts. I dont believe I have a stock strut brace in the back. 02 EX
tmessenger
Aug 14, 2010 09:50 AM
brokenarmboy19
May 22, 2007 05:39 PM
farfrumugen
Aug 25, 2005 11:29 AM
se7ensectoolate
Apr 26, 2005 11:27 PM
