wheel rub
Old Mar 14, 2006 | 05:54 PM
emooheo's Avatar
Default wheel rub
i put 16" slipstreams with 205/45's and lowered my car. my camber is at about -1.3. what can i do to get rid of my wheel rub besides make my car higher? it only does it when i take turns at 20 mph+ or when im goin 10+ and hit a bump.
Old Mar 15, 2006 | 01:41 AM
jwsimons's Avatar
Default RE: wheel rub
did you correct the camber? getting the wheel square to the body will help.. also you can roll your fenders.. kinda tweak em a little bit to get em to rollout and up.. polyeurathane bushings....
Old Mar 15, 2006 | 10:38 AM
riceburner700's Avatar
did you ever have the car cambered? if you havent then your tires will rub on the insides pretty quickly
Old Mar 15, 2006 | 11:11 PM
emooheo's Avatar
will front and rear sway/strut bars help? it only does it when i make turns at high MPH when i take em slow it doesnt.
i will also be getting a camber kit
Old Mar 16, 2006 | 01:26 AM
with a camber kit and an alignment you will be set
Old Mar 17, 2006 | 02:24 PM
KarTuneMan's Avatar
What are the exact measurments on the wheel? 16x7 or 7.5....whats the offset? needs to be at least +42mm.
Where are they rubbing?
How low did you go? and with what type of spring?
tdci29
19
Apr 9, 2007 04:57 PM
I EM 2 4DR.
Sep 24, 2006 11:51 AM
civicHBjunkie
May 29, 2006 11:45 PM
Liebers
May 4, 2005 11:43 AM
cage2b
Apr 17, 2005 11:55 PM
