Will Civic Type-R (K20A) breaks fit a '94 B16A Hatch?
Old Jul 8, 2007 | 11:25 AM
Captain_Sl0w's Avatar
Default Will Civic Type-R (K20A) breaks fit a '94 B16A Hatch?
Hi,
Will the full breaksfrom a Type-R (K20A) fit into my1994Civic VTi hatchback; the callipers, discs, pads and any other pieces required? i know the ITR system fits, but i want the newer type-r civic breaks
thanks
Old Jul 8, 2007 | 11:51 AM
civicexracer's Avatar
Default RE: Will Civic Type-R (K20A) breaks fit a '94 B16A Hatch?
y not just buy some aftermarket rotors/pads for cheaper? they'll perform better and look the same, if not better...
Old Jul 8, 2007 | 12:05 PM
i cant get my hands on aftermarket breaks here in the UK, so i was thinking that a full break upgrade to a civic type-r system would be a good alternative. Civic stock parts are cheap here too. I was quoted £60($120 roughly) for a full set of front and rear discs and pads for my B16 VTi.
Old Jul 8, 2007 | 12:09 PM
basbal123's Avatar
go to jdmcarboy.com or somthing and get the rear brake upgrades, alot cheaper
Old Jul 8, 2007 | 12:59 PM
like i said, im fromTHE UK and tuning parts for the Honda are fewer and more expensive, yet stock parts are not - hence the Type-R suggestion.
Old Jul 8, 2007 | 07:15 PM
mxs's Avatar
mxs
all 2001 and later Civics have macpherson struts and not double wishbone suspension (like your car, and integras up through 2001)
there may be a way to make the caliper bolt to the knuckle, and get bigger rotors, but it will not be a direct suspension swap like you can do with the <2001 Integra parts.
Old Jul 8, 2007 | 07:18 PM
ej6buddy's Avatar
it's not really possible (well, nothings impossible) but it WILL be cheaper to buy aftermarket upgrades rather than what you are insisting on, no matter where you live.
Old Jul 9, 2007 | 07:25 AM
ok, i'll have a look, but as a fall back, it seems ITR b18 breaks will bolt straight on if i cant find aftermarket breaks?
Old Jul 9, 2007 | 09:32 AM
cderalow's Avatar
ORIGINAL: Captain_Sl0w
you need to change out the entirety of the rear trailing arms, and the whole front knuckle assembly in order to do that
Old Jul 9, 2007 | 09:46 AM
riceburner700's Avatar
find a 94-01 integra and swap the brakes all around from that car onto yours
