How to replace the drive axle boot
13 Attachment(s)
I had to replace my axle drive boot, so i made a little DIY and hope it helps somebody someday :)
#1: Loosen the wheel nuts and the drive axle nut with the car still in the ground (only loosen) Attachment 4993 #2: Remove the drive axle nut and the give it a little push, just to make sure its loose. Attachment 4994 #3: Remove the lower swingarm balljoint nut and give it a tap up with a hammer so it comes loose. Attachment 4995 #4: Remove the steering tie rod nut, and give it a tap so its loose Attachment 4996 #5: Now you can lift the wheel hub and put it to the side on top of a jack or something, ao you´ll have more room to work on the axle #6: Cut the clamps with a cutting plier, and remove the old boot Attachment 4997 #7: At this point i wanted to use a cone tool made specificaly to change this boot, but my boot wouldn´t stretch enough so i did the old way. - You will need a friend! Have your friend to hod the axle against the tranny so it won´t come off(Circle in orange) Give a strong and swift tap with a hammer on the joint and it will come off. Attachment 4998 #8: Put the new boot in place but dont tighten it yet Attachment 4999 #9: There is a little cicle clip at the tip of the axle, make sure its there, its what holds the joint in place. Now align the spline and put the joint back in, Make sure its aligned and tap till its secure! Attachment 5000 #10: Put the boot in place and tighten the smaller clamp Attachment 5001 #11: Now the dirty part. Insert the grease, You dont want it randomly inside the boot, its suposed to be inside the joint, so i covered the bottom part, put in some grease, and with my fingers pressed it into the joint. Make sure its well greased. Attachment 5002 #12: Now tighten the big clamp on place and youre done. Reassemble in the inverse order Attachment 5003 #13: Give it a good wash and dont forget to really tighten the axle nut, the axle has dent on it, you have to dent the nut into the axle dent so it will never come off Attachment 5004 Youre good to go Attachment 5005 |
nice job.
You should specify the torque specs on the axle nut. I believe it is something like 132ft lbs. I have changed axles out wayyyyyy too many times. |
Originally Posted by cvcrcr99
(Post 782997)
nice job.
| All times are GMT -8. The time now is 04:42 AM. |
