5 Speed Conversion!!!!!PARTS NEEDED?
I hope you do a DIY so that i can follow your lead. I wanna do it on the Civic, since im gonna try to get some new suspension and i don't wanna buy another car for the B Series build.
parts list as follows
clutch pedal assembly
clutch master cyl
clutch slave cyl
clutch master to slave hard line along with rubber line(hard line goes from master to a joint where it branches to rubber which connects to the slave)
shift linkages(complete with bushings and shifter)
clutch, pressure plate, flywheel along with 5spd flywheel bolts(auto are marked AT on the top side)
pressure plate mounting bolts
5spd starter
5spd frame mounted braket(can be bought at honda)
5spd font tranny mount braket
5spd ecu(although it will run with the auto ecu)
5spd tranny mount(passenger side that mounts to the tranny)
5spd tranny(of course
when i do my next 5spd conversion ill make sure to do a write up with pics.....
clutch master cyl
clutch slave cyl
5spd starter
)when i do my next 5spd conversion ill make sure to do a write up with pics.....
