93 Civic Si Drive Axle Replace
Old Apr 20, 2007 | 12:23 PM
hjm456's Avatar
Default 93 Civic Si Drive Axle Replace
I have a 93 civic si 190,000mi and i blew the lower ball joint and snapped the axle when that happened. I am trying to get the axle out and i cant get the 1 1/4 inch bolt loose to slip the axle out. If anyone has any suggestions. I havent tried air impact yet, but i dont have an air source...yet.
Old Apr 20, 2007 | 02:09 PM
droopy128's Avatar
Default RE: 93 Civic Si Drive Axle Replace
I believe it a 33mm bolt.. using the correct socket size and use a breaker bar with an extensionof a pipe for leverage and have someone step on the brake, then you should be able to loosen the bolt.
lcgmadeira
Suspension & Steering DIYs
Oct 29, 2012 06:59 AM
anibis
Jun 24, 2011 08:55 AM
hondafaby
Jun 3, 2011 09:50 AM
RonJ
Jun 15, 2010 01:39 PM
kukanator1
Aug 23, 2007 05:05 PM
