97 auto worries
got a 97 ex sedan with auto tranny. i was wondering if there is any problems associated with them and if there is any way to beef them up just in case they are weak
RE: 97 auto worries
or should i leave it alone or swap in the 5 speed
RE: 97 auto worries
omg! my tranny is very slow in engaging. do u have the same prob.? I just flushed it btw. Still slow engagement. what do i do? 2000 EX...I d love to have a standard instead
RE: 97 auto worries
Well, if you beat the crap out of it, then you'll have a problem. Honda Automatics aren't the most forgiving. All you can do is take care of it and it should work fine for you.
RE: 97 auto worries
my tranny has yet to exhibit any problems yet . it does shift hard but i understand that this is the nature of the beast. it is a little unsettling because i'm used to gm cars and trucks (forgive me everybody). but due to cash flow problems i must stick with the auto. if it gives out what manual would someone suggest replacement with?
RE: 97 auto worries
lol thanks bud
RE: 97 auto worries
ORIGINAL: koots got a 97 ex sedan with auto tranny. i was wondering if there is any problems associated with them and if there is any way to beef them up just in case they are weak |
RE: 97 auto worries
i have a transmission problem with my 97 ex automatic transmision..its weird when im driving at 60 mph da rpm stays a 3,000 rpm then jumps up to 4,00rpm then drops down again. but when i take off its start of slow but then sounds clogged for some reason. i tried puttin lucas traqnsmission fixer and it worked for awhile but then it started again...i wanna do a transmission flush but people tell me dat my transmission will mess up even more...i havent changed da fluid in dat since last yr when i had 2 replace da transmission can anyone help me wit dis...thanx
RE: 97 auto worries
I have a 98 GMC Sierra with a 4L60E 4 speed auto in it. these transmissions are notorious for crapping out on people early, so far i have had great luck with it. 2 years ago i flushed the tranny in it and according to my dad it was the first time it's fluid had been changed. never had a problem since, it seemed to have cleaned it out real well and it shifted better. I should do it again.
The reason people advise not to do it is because older transmissions might have alot of the old clutch band material laying around in the fluid. once it is all flushed out there is very little left on the bands and it slips horrendously. this is a theory, and have yet to prove it right or wrong. But since you just recently swapped transmissions i think you should be alright. |
