97 auto worries
Old Jul 28, 2006 | 08:57 AM
koots's Avatar
Default 97 auto worries
got a 97 ex sedan with auto tranny. i was wondering if there is any problems associated with them and if there is any way to beef them up just in case they are weak
Old Aug 1, 2006 | 10:26 PM
koots's Avatar
Default RE: 97 auto worries
or should i leave it alone or swap in the 5 speed
Old Aug 1, 2006 | 11:42 PM
POLYTHING's Avatar
omg! my tranny is very slow in engaging. do u have the same prob.? I just flushed it btw. Still slow engagement. what do i do? 2000 EX...I d love to have a standard instead
Old Aug 2, 2006 | 01:19 AM
D16Punk's Avatar
Well, if you beat the crap out of it, then you'll have a problem. Honda Automatics aren't the most forgiving. All you can do is take care of it and it should work fine for you.
Old Aug 2, 2006 | 05:35 PM
koots's Avatar
my tranny has yet to exhibit any problems yet . it does shift hard but i understand that this is the nature of the beast. it is a little unsettling because i'm used to gm cars and trucks (forgive me everybody). but due to cash flow problems i must stick with the auto. if it gives out what manual would someone suggest replacement with?
Old Aug 2, 2006 | 11:32 PM
POLYTHING's Avatar
lol thanks bud
Old Aug 3, 2006 | 06:08 AM
97 Black Civic's Avatar
ORIGINAL: koots
I have the exact same car. I have 119,000 miles on it and have had no problems. I don't race it but I ddo drive aggressively.
Old Jan 15, 2007 | 09:21 PM
iLLeStRiCaN's Avatar
i have a transmission problem with my 97 ex automatic transmision..its weird when im driving at 60 mph da rpm stays a 3,000 rpm then jumps up to 4,00rpm then drops down again. but when i take off its start of slow but then sounds clogged for some reason. i tried puttin lucas traqnsmission fixer and it worked for awhile but then it started again...i wanna do a transmission flush but people tell me dat my transmission will mess up even more...i havent changed da fluid in dat since last yr when i had 2 replace da transmission can anyone help me wit dis...thanx
Old Aug 9, 2007 | 02:13 PM
koots's Avatar
I have a 98 GMC Sierra with a 4L60E 4 speed auto in it. these transmissions are notorious for crapping out on people early, so far i have had great luck with it. 2 years ago i flushed the tranny in it and according to my dad it was the first time it's fluid had been changed. never had a problem since, it seemed to have cleaned it out real well and it shifted better. I should do it again.
The reason people advise not to do it is because older transmissions might have alot of the old clutch band material laying around in the fluid. once it is all flushed out there is very little left on the bands and it slips horrendously. this is a theory, and have yet to prove it right or wrong. But since you just recently swapped transmissions i think you should be alright.
klipschfan4life
Apr 24, 2009 03:25 AM
StifflersMom
Jun 11, 2008 07:44 AM
justinprime
May 15, 2006 08:59 PM
Shandles
Oct 21, 2005 11:36 AM
Auto98EX
Aug 6, 2005 04:56 PM
